I bought my friend a refurb DV9653 off of ebay, and it is in great working condition. The only problem is, when it's running off of battery power, the wifi works fine! Running off of AC power from the startup works fine as well. When the laptop is running off of battery power in windows however, and you plug in AC power, it disables the wireless. When this happens the wifi light turns from blue to orange. If I go to the network connections, it says enabled, and switching the slide button back and forth from enable to disable and back does nothing! It remains orange for about 30-45 mins, then finally picks up wireless and connects fine! Going from AC back to battery stays connected fine, but battery to AC disables every time. Any ideas? I've uninstalled the 3rd party HP wireless wizard software and enabled the Wireless Zero Configuration. I've also installed the latest WLAN driver and checked power settings, but nothing seems to change the problem!
