MugsyGoten
- Mar 30, 2003
I just built my new computer, everything was going fine, but I tried installing a corporate WinXP along with my regular XP Pro, and everything was going fine...
That is until it went to the setup. At the setup, I have 5 seconds or so to select my OS, and by default its on the XP Pro Setup...like it should be. The problem is there is a bad something in the program and my computer goes to an error screen which makes me restart the computer, and then it does the same thing. The deal is that I cant use the keyboard to switch to the regular XP so I can UNDO what Ive done here. I can however enter the BIOS for some reason. Can anyone help me out on how to fix this monstrocity?
EDIT: I swotched keyboards and for some reason that worked. However, now that Im in normal windows, I need to know what Ive gotta delete/alter in order to get that Windows XP Professional Setup option taken away. I dont think it system restored before then, so if anyone out there could tell me what I need to delete to be back where I started...that would be awesome.
Thanks in advance!
Thanks in advance!
