ok Ill try and make this is short and detailed as possible...
I am having problems with my USB ports losing power and getting stable overclocks with my new Q6600 CPU....
Asus P5B- Deluxe
Core 2 quad Q6600
eVGA 8800 GTS 512mb (overclocked to 800/1950/1050)
Corsair XMS2-6400 1GB x 2
Seagate 320GB x 2 in RAID0
Lite-On 16x DVD-R SATA x 2
floppy drive with built in mem card reader
Sound Blaster X-Fi Platinum
Scythe S-Flex 120mm fan receiving power from the CPU fan header
Antec 120mm fan for exhaust getting power from PSU
generic 120mm fan for intake getting power from PSU
and for USB...
Logitech G15 keyboard
Logitech G7 Mouse (with USB receiver and USB battery charger)
WD 1TB external HDD
Hauppage HD TV tuner (sucks alot of power I hear)
30GB Zune (syncing and charging via USB)
Canon Pixma all in one printer
the USB mem card reader thats built into the floppy
and sometimes a xbox360 usb controller
Now all the above is being powered by an Antec 550watt Nvidia SLi certified PSU. I wont even get into the CPU overclocking probs since it runs fine at stock speeds. My system WAS running perfect with my superclocked eVGA 8800GTS 320mb and core 2 duo E4400 (i believe) 2GHz CPU that I had overclcoked to 3GHz by 10x300. Since I upgraded to the new CPU and vid card last week I am having constant USB problems that are this....
the key and mouse no longer work in games just drop in and out of power constantly, usually stops when I get back into windows, but not always. My Zune will not work at all anymore, the TV tuner cards will work for a few hours and then pop up a "to much power draw on the USB hub" error message. mem card reader has quit working. My external hard drive never has problems, but then again it has its own power supply....pretty much anything receiving power from a USB port freaks out now.
I went to ASUS' website to get help thinking my mobo was failing, and came across this power supply calculator and according to it I need a 700watt PSU minimum. So my question is this....I have been thinking failing mobo all week, but do you guys think it could just be that my 550watts isnt enough to power everything in my system????
This is driving me nuts, and I would really like to get back to gaming and trying to overclock this new Q6600 so any help/opinions would be appreciated!
Asus P5B- Deluxe
Core 2 quad Q6600
and for USB...
WD 1TB external HDD
