wierd situation with highpoint 2320
ilkhan
Im trying to backup my array so I can destroy it and start over with GPT. Simple premise.
I have a 5x750 R5 array (With a standard partition table (2048GB limited) which limit I didnt notice until AFTER adding the last drive.)
I have ONE empty 750 drive, and have deleted or saved elsewhere enough data to be down to two 750 drives capacity (calculated to 692GB/695GB out of 698GB after formatting)
Highpoint, in their infinite wisdom, doesnt let you remove a drive from the array. So I cant degrade the array, copy data to IT, and then wipe/rebuild, as I hoped.
Ive tried just pulling the drive and attaching it directly to the motherboard. The drive shows in BIOS as blank label. No track info, not "none", but just blank. Its spooky. I think this comes from having been intialized on the 2320.
Id very much like to avoid having to buy ANOTHER 750 to facilitate this transfer.
Does that make sense?
Ideas?
Might I be able to convert to R0/JBOD (4 drive) and do it that way?
I've ran into this problem before. If you have staggered spinup enabled, and you insert a certain model of Western Digital drive into a Highpoint branded raid card, the firmware of the WD drive becomes changed somehow and will no longer work outside of a Highpoint card - either the drive does not spin up at all, or it gets detected as a 0gb blank drive. I don't think either Highpoint or WD want to admit fault, but it's a known problem. RMA your drive if you want to use it outside of a Highpoint card, otherwise, you're stuck with using it on your Highpoint card only.
Since your raid is so small, I'd suggest just getting a few 1.5tb drives and backing up / restoring using those. I'm not sure if the Highpoint supports migration to a smaller raidset. It may only expand to a larger one, and expansion may be risky if a failure occurs during the process.
as I said, Ive got the array down to 675GB of used space, enough to fit on a single one of the 750GB drives Im using. Im gonna try dropping to raid 0 or JBOD and hopeing for the best.
If I can pull out a single drive Ill be fine. And I want to continue using the controller, its just annoying that it wont let me a pull out a drive easily.
edit: ORLM to R0 started, and it let me use only 4 disks. What a PITA. ETA 48 hours for the migration. Figure 3 hours for moving the data (conservatively), another 24 to build the new R5, another 48 to expand to 6 drives I repeat, What a PITA,
Hmm glad I ran across this. I just purchased my 2320. Is the unusable HD a WD only problem or has anyone experienced it with other manufacturers?
dont turn on staggered spinup and you should be fine. Emphasis on *should* and not *will*.
They are AAKS drives.
I'm running 4x500 WD AAKS on a RocketRaid 2300 and have moved the array to another device at one point in time. I was pretty sure the AAKS line did NOT support staggered spin up, so I never tried to enable it.
Certainly possible. On mine I hear the drives spining up individually, even though its set NOT to stagger the drives. :whatever:
got a reply back from highpoint, figured Id post it here
Highpoint rep said:
Hello,
You cannot normally remove a disk from any array.
If the array was recently verified, you can attempt to duplicate a failure (fault/unplug one of the disks).
What kind of disks are you working with?
Some WD drives will behave this way if staggered drive spinup was enabled - these disks do not support this setting, yet may still react to it. Once enabled, it cannot be disabled, and the disks will only be recognized properly by controllers that support this feature (other RAID cards). WD is aware if this issue.
Regards,
HighPoint Technologies, Inc.
Customer Support Department
and reply asking about a possible solution to the staggered spinup issue
Hello,
Some customers have reported that WD either replaced the disks, or had sent utilities to correct the issue (though we have not been able to obtain a copy - perhaps a firmware update for specific models).
Regards,
