bigbadgreen
- Oct 2, 2003
So here is my problem. I have a gigabyte GA-K8NSC-939, 2 gigs of kingston hyper x ddr500, winchester 3000+, slightly overclocked 250 x 9 @ 2250, I have one old generic cdrw drive, and a seagate 160GB hard drive. It is watercooled with a home built setup, and a DD block. the vid card is a radeon 8500 LE 128MB agp card. I'm running windows XP fully updated. It had a generic powersupply, key word had, more on that later. I use this as a server, occasional folding box, and to test things out.
The problem is that everything was working perfect about two weeks ago. I shut down, everything was fine, good shutdown, no issues. No viruses, it's pretty much clean, it has barely anything installed on it. I went to power it up last night and I got nothing. It doesn't seem there is any power to the motherboard at all. No fans spin up, no lights, no nothing.
My first thought was maybe the power supply finally gave out. It's about 5 years old and generic. So I swapped in an antec Neo HE 550 I had as a backup. Still nothing. I tried the power supply on my main box and it works fine. There are no scorch marks or aything that lead me to believe the supply went bad I then unplugged everything that isn't needed, leaving only one stick of ram, power supply, and cpu. Tried to start and nothing. I rechecked ther wiring on my switches to make sure there were no shorts, there aren't. I then pulled the mobo out of the case thinking it might be a ground issue, it still won't do anything. I have the system speaker connected and not even a single beep. I've tried to reset the cmos, through both the jumper and by leaving the battery out until I just got home right now. still nothing.
There is no bulging capacitors, and no leaks from the watercooling. I have checked everything, down to a handheld blacklight near the mobo to detect any dye residue from dried up UV dye. My next thought was maybe a power spike did it in. It was still plugged in during those two weeks. However my main box is always on and plugged in to the same surge protector, a decent apc one. So if there was a spike how did it get through the surge protector destroy the one mobo, and not even restart the other computer?
I'm at my wits end. I'll probably go buy another cheapo mobo, probably not a gigabyte this time.
Any suggestions would be greatly appreciated. If there is something I have missed, I'm willing to try anything at this point, including voodoo or a scarifice to the computer gods by burning my duron 900 board and cpu.
