Wierd Problem with P5N32-E SLI
natermeister
I just got my new build, with an E6700, 2GB of DDR2 1066, and the afformentioned motherboard running. All in all it works fine, with one major and quite strange problem.
After I do a restart, or exit the BIOS, the machine fails to POST. If I simply shut it down and turn it back on, it POSTs fine. I thought it could be a grounding problem so I took it out of the case and ran it on an anti-static bag, the problem persists. I also thought about improperly seated RAM, but reseating it did not change the situation.
I called ASUS and they didn't have anything for me besides trying different components, which is a pretty weak 'tip' and I don't think it would work anyway. All of the components I have worked fine in a previous machine. Exceptions being the memory and processor, but problems with them would preclude the machine from POSTing at all, I would think.
If you have any ideas, I'd greatly appreciate your replies. Thanks in advance.
-Nater
I too would like to know more about this problem. I read some of the user reviews on Newegg about this board and a lot of them had the same problem. If there is a solution to this it would be great to know because I am trying to find the right motherboard for my upcoming build and I have been seriously looking at this board.
Not related to your problem, but you shouldn't run a motherboard on an anti-static bag, as they are usually conductive.
Wow, I did not know that anti-static bags were conductive. That certainly seems to go against intuition now doesn't it?
I didn't see anything about this problem popping up on ASUS' support forum, but I'll have to check Newegg.
I got a hold of a better ASUS tech support guy today, hey said this motherboard needs 3A on the -5V rail. My power supply doesn't even have such a rail. I'm having trouble finding one that does.
