Ok first off my problem is whenever I'm playing CS it feels really laggy and the sound seems to mess up. When I'm playing with mp3s(source is an external usb2.0 HD) the sound from winamp will cut in and out but the sound in game will continue but will still lag. Not only does the sound lag but it also feels like the whole game is lagging. Now my first thoughts were well im using a usb headset and a usb mouse so maybe theres a problem there. But after using my soundblaster live instead of the usb headset I still have the problem.
Now I have used my onboard SATAraid with 2 raptors in raid 0 and in single mode and have had this problem. I am now using the adaptec scsi card with a maxtor atlas 15k and am still having this problem. But whenever I use the onboard IDE with that 60GB drive I posted in the specs I don't have this problem.
Here's a pic of my irqs. As you can see the yellow question mark is my onboard SATAraid that is disabled in the bios and still is detected by windows.
My specs are:
Intel D845PEBT2 mobo
Pentium 4 2.53Ghz
ATI Radeon 9600Pro(not oc'd) using cat. 3.8s
Antec True 350 PSU
Adaptec 39160 SCSI Host adapter
Maxtor Atlas 18.2GB 15K 68pin
Soundblaster Live Value and USB Plantronics DSP500 Headset
External WD 120GB Combo Drive (usb2.0/firewire)
Also have a WD60GB in there that I was using.
EDIT: Running WinXP Pro /w SP1
If you read all the way through I thank you because I know most won't.
~Joel
My specs are:
Pentium 4 2.53Ghz
Antec True 350 PSU
~Joel
