Wierd p5e/memory problem
wiper
My machine's been running fine for the last few months but all the sudden in the last couple days I started getting app crashes and bsods. Last night it devolved into not booting and finally not posting at all. Naturally I thought it was the mem but then when I tried putting some known good mem from another machine it. Now the machine would post just fine but when it got to the vista loading screen it hangs on crcdisk.sys. After some more troubleshooting I discovered that I couldn't even boot the vista dvd which leads me to believe it's hardware related.
So I started moving the mem around and trying different combinations with both sets and found that the machine will post and boot up into vista *only* when there is only 1 stick installed in the second slot. One of the known good sticks in any other slots or both installed in any combination of the slots results in the crcdisk.sys hang. Either of the sticks I thought were going bad in any slots except the second cause it not to post but installed singly in the second slot the machine boots up just fine.
So, I've ruled out vista because it's been working and I can't even boot the dvd.
The machine runs fine on the mem I thought was going bad as long as it's installed singly in the second slot just like the known good mem. This all leads me to believe it's the motherboard but the symptoms just don't make any sense to me...any ideas?
For starters ensure the PSU is providing the system with clean power, and reset the CMOS.
Checked the psu with my multimeter, all voltages are in spec. I didn't mention resetting the bios before but it was the first thing I tried, several times.
