Alright, last Thursday I installed an SI-97 Heatsink and a good reliable 92mm fan(I've had it for years, but it has worked great from day one). I also installed another stick of ram. All in all here is the setup.
Asus A7N8X-X
AMD Athlon XP 3000+ (2.345 ghz 1.75 vcore)
Gigabyte Radeon 9800 pro 128mb (430.2mhz/365.4mhz)
1 gig of kingston valueram PC3200 (2 x 512mb)
My temperatures are in comfortable range (mbm reads 41* socket, 34*diode at idle and usually 50* and 44* under load). I don't get any wierd things while under use, but if I let my computer screensaver run overnight, I will wake up and my computer will have all the startup windows up (steam, AIM, ares, etc), suggesting it rebooted at some point. What could the problem be? If I go to class and it's running at 100% with the screen saver, no problem. But for whatever reason, overnight, it will turn off.
Any ideas?
Asus A7N8X-X
Any ideas?
