board2death986
- Aug 13, 2005
Well first of all I tried to install my 7900 GTO from a rig i'm now using as a file server into my htpc, and i found it's fried, as any system i install it into won't post.
Now after replacing my vid card in the server with an old voodoo (which works fine) as soon as I start booting after post it gets to my USB front card reader and after it finishes that I get an error message "USB OVER CURRENT STATUS DETECTED", and the system shuts down.
In addition to that earlier the other day I noticed the fan on my power supply is dead. I'm guessing the problem is obviously the PSU, although with the amount of wiring I guess maybe I should check all my USB connections to the motherboard (only ones are for top and front panel hubs), the top mounted isn't guided by the normal square design, could installing that backwards damage other components (doubtful this is the cause as i've used the top USB hub without problems)
*edit* i must be tired, my title reads Wierd allevents. . . i could've sworn i just typed Wierd Events?
