I recently Installed Vista home basic on my mothers computer.I did a clean install! When I try to activate it it tells me that the cd key I entered can only be used for upgrade not clean install.So please tell me how activate it.....TIA!
Um...theres a sticky about this..
"FAQ Links - This is where the forum FAQs are. "
Does your Vista box/package say UPGRADE or FULL VERSION ?
If it says upgrade, you were supposed to do an upgrade from a previous version of Windows, which sounds like your cdkey is an upgrade, but you didnt do an upgrade.
