Widescreen Monitors and Video Cards
blinkdev
Does anyone have any experience with using a widescreen monitor with a 6800GT? Will the 6800GT be able to handle a 19inch widescreen? And if not, then does anyone have suggestions for a capable videocard?
I've sort of lost touch with video card technology and its capabilites, so any help would be greatly appreciated.
Limited and only close experience. 6800 ultra driving a higher res 2405 panel and it's working ok in DS2 and Wow. These days you can get a 7900 GT and up your GPU horsepower if you find that the 6800GT is not enough. But try it first :)
The capabilities of a video card is generally based on the complete amount of pixels rendered. So, a 19" widescreen is generally going to have a resolution of 1440x900, or a 16:10 ratio, and 1 296 000 pixels rendered. In contrast, a standard LCD or CRT monitor will have a generic resolution of 1600*1200, or a 4:3 ratio, and 1 920 000 pixels rendered. So, as you can see, driving a 19" widescreen is likely to be easier than driving a CRT or LCD at 1600x1200, because the total amount of pixels rendered for each frame is significantly less.
Also, a 7xxx or X1K series card will yield better results with resolutions that have higher pixel counts than 1.8 million, as they are designed with larger internal frame-buffers to support higher resolutions.
That said, look how a 6800 performs in 1600x1200 tests, and you'll get a somewhat rough estimate of how it will perform on a 19" WS.
