Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Well you could go with any of the primes like the 20mm f/2.8 at about $500. Great for low light landscapes and, close-ups. It has about a 10.5 focusing distance and, a 94 degree field of view. Or I would go with a fisheye for maximum wideness and, playability. In that case Sigma makes an 8mm f/3.4 or, f/4 the first is like $50-60 higher than the second. Myself I plan on a fisheye next. Minimum focusing is like around 5 inches.
