wich one!
philbrown23
ok Ima get a new P45 mobo! my question is wich one? I have narrowed it down to 4!
Gigabyte GA EP45-DQ6
Gigabyte GA EP45-DS4
MSI P45 Platinum
Biostar TP45-HP
wich one is the best? I'm leaning towars the DS4 or the biostar, but dont know HELP!
if you're going for a p45 board i say go for one of the DFI's they're great.. or if you wanna splash the cash look at the maximus formula 2 from asus its nice, only thing that puts me off is the price you can get a x38 board for the same cost as some p45 boards.
The DS4 out of the boards listed there, also you could look at th P5Q-e or the DFI boards.
What do you want to do with the board? (ie. overclocking, gaming, general use/net surfing) Also I highly advise you look into the Asus P5Q series, great boards, there is a huge thread dedicated to them floating around in the Motherboards Section. They are definitely best bang for you buck.
