so i was wondering wich cats are the most stable right now ? currently using the 5.3s. and playing cs:s fine, heard that 4.12 are better ? wich one do you prefer ?
personally, i think it really depends on the card. with my 9800 pro, i used the 4.12s or 5.6's with the best effect, but with my x850xtpe, the 5.7's are the best.
personally, if it's an older card like a 9x00, i'd use the 5.6's then the 4.12's
