Wich block for G33 northbridge
DeaffyMan
Hey guys!
I plan to upgrade my rig to a G33 µATX solution. The board I have in mind is the GA-G33M-DS2R. Since some people are saying that their northbridge runs hot especially if OC'ed, I'd like to hear opinions about whether it is worthwhile to include the nortbridge into the loop and which watercooling block people here have used on these chipsets or this board, if any.
Cheers,
I'd use a HSF unit specifically devised for hot-running NB chips over a waterblock...
It'll cool just as well and prevent any restriction/heat dump that might hurt your CPU temps a bit.
Ok, thanks. Before I go looking: Any epxerience with such a fan/HS combo on the G33 that works reasonably well and still allows fitting the CPU waterblock and the Grpahics card right next to it?
