EliteGeek91
- Jan 6, 2012
Hey all, have a very weird connection issue. It takes me 10+ times to connect to my modem via Wi-Fi. I also connected another router to that (A new hotspot), and still have the exact issue. Although if I go to a friend's Wi-Fi, or somewhere such as Starbucks, it connects on first try, everytime...
It started happening, so first I reset the modem (Set factory defaults), no go. So then I went into device manager, removed the Broadcom drivers, reinstalled them from the HP website, same issue. Reinstalled Windows, issue still continues. I even removed the WPA encryption, and changed the router name, and issue still happens..
So now I'm puzzled since I did a full reinstall of Windows, new drivers, etc.
Here's what I get below when I try to troubleshoot my error.
Oh, and the network below that I wanna connect to, is "Woods".
"Elite" was my 2nd router, but issue happens on that one also.
InformationalDiagnostics Information (Network Adapter)
Details about network adapter diagnosis:
Network adapter Bluetooth Network Connection driver information:
Description . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Manufacturer . . . . . . . . . : Microsoft
Provider . . . . . . . . . . . : Microsoft
Version . . . . . . . . . . . : 6.2.9200.16384
Inf File Name . . . . . . . . . : C:\Windows\INF\bthpan.inf
Inf File Date . . . . . . . . . : Wednesday, July 25, 2012 8:15:36 PM
Section Name . . . . . . . . . : BthPan.Install
Hardware ID . . . . . . . . . . : bth\ms_bthpan
Instance Status Flags . . . . . : 0x180200a
Device Manager Status Code . . : 0
IfType . . . . . . . . . . . . : 6
Physical Media Type . . . . . . : 10
Network adapter WiFi driver information:
Description . . . . . . . . . . : Broadcom 802.11n Network Adapter
Manufacturer . . . . . . . . . : Broadcom
Version . . . . . . . . . . . : 5.100.245.20
Inf File Name . . . . . . . . . : C:\Windows\INF\netbc63a.inf
Inf File Date . . . . . . . . . : Wednesday, July 25, 2012 8:37:09 PM
Section Name . . . . . . . . . : BCM43XNG_NT61
Hardware ID . . . . . . . . . . : pci\ven_14e4&dev_4357
IfType . . . . . . . . . . . . : 71
Physical Media Type . . . . . . : 9
InformationalDiagnostics Information (Wireless Connectivity)
Details about wireless connectivity diagnosis:
For complete information about this session see the wireless connectivity information event.
Helper Class: Auto Configuration
Initialise status: Success
Information for connection being diagnosed
Result of diagnosis: No problem found
Interface GUID: *Removed)
Interface name: Broadcom 802.11n Network Adapter
Interface type: Native WiFi
Connection incident diagnosed
Auto Configuration ID: 2
Connection ID: 3
Connection status summary
Connection started at: 2013-02-13 00:57:22-475
Profile match: Success
Pre-Association: Success
Association: Fail
Security and Authentication: Not started
List of visible access point(s): 2 item(s) total, 2 item(s) displayed
BSSID BSS Type PHY Signal(dB) Chnl/freq SSID
(Removed) Infra g -78 1 WIN_087
(Removed) Infra g -63 1 Woods
Connection History
Information for Auto Configuration ID 2
List of visible networks: 2 item(s) total, 2 item(s) displayed
BSS Type PHY Security Signal(RSSI) Compatible SSID
Infra g Yes 24 Yes WIN_087
Infra g Yes 70 Yes Woods
List of preferred networks: 3 item(s)
Profile: WLAN-11g-GW
SSID: WLAN-11g-GW
SSID length: 11
Connection mode: Infra
Security: No
Set by group policy: No
Connect even if network is not broadcasting: No
Connectable: No
Reason: 0x00028003
Profile: Woods
SSID: Woods
SSID length: 5
Security: Yes
Connectable: No
Reason: 0x00028006
Profile: Elite
SSID: Elite
SSID length: 5
Security: Yes
Connectable: No
Reason: 0x00028001
Information for Connection ID 3
Profile: Woods
SSID: Woods
SSID length: 5
Security: Yes
Pre-Association and Association
Connectivity settings provided by hardware manufacturer (IHV): No
Security settings provided by hardware manufacturer (IHV): No
Profile matches network requirements: Success
Pre-association status: Success
Association status: Fail 0x00038002
Association reason code: 0x00000002
Information for Auto Configuration ID 1
SSID: WLAN-11g-GW
SSID length: 11
Security: No
Connectable: No
Reason: 0x00028003
Profile: Woods
SSID: Woods
SSID length: 5
Security: Yes
Connectable: Yes
Profile: Elite
SSID: Elite
SSID length: 5
Security: Yes
Connectable: No
Reason: 0x00028001
Information for Connection ID 2
Connection started at: 2013-02-13 00:57:20-866
Auto Configuration ID: 1
Profile: Woods
SSID: Woods
SSID length: 5
Security: Yes
Information for Connection ID 1
Connection started at: 2013-02-13 00:57:19-178
Profile: Woods
SSID: Woods
SSID length: 5
Security: Yes
Interface GUID: (Removed)
Result of diagnosis: Problem found
Issue referred to: RNWF MSM Helper Class
Root cause:
Windows could not connect to "Woods"
You can try to connect again.
Repair option:
Resetting your wireless network adapter
This will disable and then enable the network adapter "WiFi" on this computer.
InformationalDiagnostics Information (Wireless Network Adapter)
Details about wireless network adapter diagnosis:
Helper Class: Native WiFi MSM
Profile: Woods
SSID: Woods
SSID length: 5
Security: Yes
Root cause:
Wireless association to "Woods" failed
A response was not received from the router or access point.
Detailed root cause:
Wireless association to this network failed. Windows did not receive any response from the wireless router or accesspoint.
Repair option:
Look for causes of low wireless signal quality
The signal is weak due to distance or interference.
Windows Help and Support can provide more information about this problem.
InformationalNetwork Diagnostics Log
File Name: C2964D80-88FA-4462-B7FC-F2CB913A791D.Diagnose.0.etl
InformationalOther Networking Configuration and Logs
File Name: NetworkConfiguration.cab
Collection information
Computer Name: WOODS
Windows Version: 6.2
Architecture: x64
Time: 13 February 2013 00:57:33
Publisher details Expand
Windows Network Diagnostics
Detects problems with network connectivity.
Package Version: 1.0
Publisher: Microsoft Windows
Internet Connections
Find and fix problems with connecting to the Internet or to websites.
Publisher: Microsoft Corporation
Connection ID: 3
Association: Fail
Connection History
SSID: WLAN-11g-GW
SSID length: 11
Security: No
Connectable: No
Reason: 0x00028003
Profile: Woods
SSID: Woods
SSID length: 5
Security: Yes
Connectable: No
Reason: 0x00028006
Profile: Elite
SSID: Elite
SSID length: 5
Security: Yes
Connectable: No
Reason: 0x00028001
Profile: Woods
SSID: Woods
SSID length: 5
Security: Yes
SSID: WLAN-11g-GW
SSID length: 11
Security: No
Connectable: No
Reason: 0x00028003
Profile: Woods
SSID: Woods
SSID length: 5
Security: Yes
Connectable: Yes
Profile: Elite
SSID: Elite
SSID length: 5
Security: Yes
Connectable: No
Reason: 0x00028001
Profile: Woods
SSID: Woods
SSID length: 5
Security: Yes
Profile: Woods
SSID: Woods
SSID length: 5
Security: Yes
Root cause:
Repair option:
Profile: Woods
SSID: Woods
SSID length: 5
Security: Yes
Root cause:
Repair option:
Architecture: x64
