Wi-Fi card for upcoming build...
crABtoad
Hey all, going to be picking up an Intel 633AN.HMWWB mPCIE wifi card for a build I'm doing.
I'm kinda stumped regarding where to buy antenna connectors and which antennas I would need to get for it. It seems to come as a standalone part and I'm just not sure what antennas or antenna wires to get for it.
I don't have any parts I can use for this currently, or I would just cannibalize something and see if it worked.
Having a noob moment, any help? :rolleyes:
Seithennin
Those antenna connectors on your Intel mPCIE wifi card are called UFL connectors.
so you would need to pick up 3 connectors/antennas, and hook up all 3 for the best signal strength.
Maybe something like this?
http://microcontrollershop.com/product_info.php?products_id=2480
Or this??
http://accessories.eracks.com/product/p-int-antenna-assy-k1/
Or even this should work..
http://www.techship.se/products/internal-gsm-umts-wifi-antenna-2jmas01/?gclid=CPzNrYfch7ICFchgTAodiEAAOA
Hope this helps, good luck with it !!
crABtoad
Thanks for the info!
These are almost exactly what I need, but I think you've provided me with the information I need to move ahead with this project.
I need U.FL to Coax bulkheads that work for 2.4Ghz and 5Ghz, but at least I know what I'm looking for now!
:D:DD:
crABtoad
Yeah I'm building a Thin Mini-ITX inside of an old radio with a 160W power brick. It's got a slot for an mSATA card (using for SSD) and another half-height mPCIE card (using for wifi). Thanks for the reply regardless though.
