Later this week I'll be getting a small form factor Acer Aspire XC-603 desktop PC. The only thing it has for expansion is a single Mini PCI-E slot.
So I'm thinking I might as well use that slot to add a Wi-Fi + Bluetooth Mini PCI-E card.
These are easy enough to find. But what seems to be impossible to find is a bracket containing antennas that can be installed in the case. I'm aware that some people drill their own holes into their cases into which they insert the RP-SMA connectors for antennas. But I don't want to do that (especially to a new system I don't want to void the warranty for).
I'm surprised I haven't been able to find a simple bracket with RP-SMA connectors that I can insert into the case so I can attach external antennas. Does anyone know if such a thing can be bought anywhere (I'm in the UK)?
