Swiftech Web Page said:Graphics card compatibility and retention mechanism
The MCW50 ships with a dual retention mechanism composed of spring loaded screws providing off-the-shelf compatibility with all ATI® Radeon products (including the latest X800 series) as well as nVidia® GForce families of products up to the GeForce 4.
Optional hold-down plates are available for nVidia FX, PCX and GeForce 6 series with their respective retention kits as shown below. The product can also be installed with other graphics processors by using permanent bonding agents, such as thermally conductive epoxies. Swiftech guarantees compatibility with ATI and nVidia reference models only.
Spring loaded assemblies feature compression limiters, to prevent over-tightening of the water-block to the graphics processor.
Erasmus354 said:I would imagine that site you are looking at simply has not updated the page to state that it will work on the newer x800 series.
BigTaf said:seems very odd
I can confirm both my 9800pro and my x800xt have the same mounting holes, ones made by ATI, ones built using ATI
