While the 85% of gpu market share will support Freesync.
Freesync is proprietary to AMD so only they will be supporting it. So that means less than 18% if you are counting integrated. Although it will be mostly useless for integrated.
That's a good point. Toshibia was the main backer of hd-dvd and they now make blu-ray players.
You forget Intel just backed it? What % is that?
as usual, you dont know what you are talking about.
Freesync is AMDs implementation of Adaptive-Sync.
Anyone can use it, its open, and free
hense freesync.
If you want a pretty sticker, sure, do what AMD wants.
if not, whatever.
it makes no diference,
Its 100% free and 100% compatible.
AND 100% freesync compatible.
Thats right Chuckles, if you make an A-sync monitor, it 100% compatible with Freesync...
It is? So if I don't have a "Freesync" monitor but it does support a-sync, then I won't require any special driver or anything to make it work on my AMD card? Serious question.
blah blah blah
Freesync is 100% proprietary.
So what? A-sync isn't, and freesync works on a-sync monitors.
So by that logic since gsync works on Linux....gsync is open!
Intel did NOT back Freesync.
nVidia mobile GSync is based on adaptive sync (because the gsync module used too much power for a laptop). Since they use the same chips in mobile as on the desktop, there's no technical reason for them to not do so. That said, unless the monitor makers revolt over the premium they have to pay for the gsync module; or adaptive sync becomes a standard feature in commodity monitors I don't see nVidia rushing to add support for adaptive sync on the desktop either.
http://www.anandtech.com/show/9303/nvidia-launches-mobile-gsync
Intel has advised they will support ADAPTIVE Sync. A lot of tech sites erroneously reported it as Freesync. The original article they based it from, however, explicitly states Adaptive Sync.
http://techreport.com/news/28865/intel-plans-to-support-vesa-adaptive-sync-displays
It remains to be seen how future iGPU iterations employ the tech - it could be very well through Intel's own solution they devise, as they compete with AMD's APUs.
If you want to talk major manufacturer adoption - Dell's first variable refresh rate monitor will be G-Sync - the S2716DG. That isn't a particularly good sign for AMD.
FFS people! Freesync = Async! Freesync is basically just a fancy name AMD slapped on top of it and on the monitors that are AMD "approved", but any Adaptive Sync monitor is compatible with Freesync cards and whenever Intel releases an Async compatible chip they will be compatible with Freesync monitors. Unless something has changed lately this is how it goes.
If Adaptive Sync and Freesync were absolutely identical, there would be no reason for the Freesync moniker to begin with. One would imagine AMD has done some tweaking to the open standard to necessitate a change in language.
Have we seen any explicitly labeled Adaptive-Sync monitors that are supported by AMD hardware? Why is it AMD would need to certify a monitor for Freesync use if it adheres to the standard?
^ This guy gets it.
Because they have Gsync which is much better?
SImple, it does not make them money and that is all that matters.
Some companies like to pay for things like employees, R&D, marketing, etc.
Other companies (AMD) like to get rid of those things and reward their executives instead.
I assume that means you have a g sync monitor with the most expensive Nvidia cards available, right? After all, have to support those Nvidia employees.
Isn't async limited to a smaller hertz range? Where as gsync isn't?Yup, like Nvidia will be getting your money when it changes to ASync.
Beh.
How is it much better? Because I say so doesn't count.
Also I believe gsync chips are tuned per monitor for optimum performance
Without gsync module it's not easy to control overdrive which will result in ghosting, you can't find any freesync monitor without ghosting issues. Coming from a monitor with tons of it, I don't mind the gsync premium cost at all.
Other than Nvidia does support DP Adaptive Sync in laptops...
1) Because there's not much pressure to abandon G-Sync. It's currently the superior product compared to DP AS.
2) Because the price of adding G-Sync to monitors can be significantly lowered if necessary.
3) Because it's not a mainstream feature users are demanding. Users who want it are willing to pay a premium at a high enough volume that G-Sync monitor prices don't need to be reduced. IOW, G-Sync monitor makers are offering a non-commoditized product and can enjoy a higher profit margin.
4) Because by not supporting DP AS, Nvidia deprives AMD of the benefits of much higher scale to widen the price difference between DP AS compatible and G-Sync compatible displays. Plus it would probably hurt the manufacturers who currently sell G-Sync monitors.
Read the entire article. Nvidia mobile g sync requires the display to support panel self refresh. This makes it easy to support frame rates below thae panel minimum refresh.
Psr adds additional cost to a panel (less than g sync module), so it won't be available on just any old panel. AMD freesync does not support psr, and thus is limited to the minimum panel refresh rate.
next time research before you complain![]()
LOL you really don't understand it either. You realise that eDP standard specification requires panel self refresh and it was introduced in 2011 in eDP 1.3.
AMD already support this. They have supported it for years because they have had to build their APU's to meet this requirement. It's the reason why all GCN APU's (even GCN1.0 APUs) have full support for freesync but GCN 1.0 desktop cards don't.
Intel mobile parts that have eDP 1.3 or later also have full support for panel self refresh.
All Nvidia are doing are using the specification that exists already. And it's basically Adaptive sync screen connected to timing controller and framebuffer on a GPU.
