Why wont my beast boot?
birdmw
Well, I finally got my new ram (200$'s for 4x sticks ddr2 1 gig) <---shoot, this could be the problem
my new ram waterblock, my my two mobo waterblocks so and she boots up, tells me something about needing a cmos reset, so I unhinge the gigantic 8800's and reset the tiny cmos only to get my computer booting through some bios crap and then going blank. Off, Dead. This happens without fail every time the computer boots and I cant figure why, would ram cause it to do that?! also it said something about resetting cmos timings in that one boot message I was talking about but I have NEVER overclocked ANYTHING so Im not sure what it could've been refering to. incompatability? Also there is a bit of air that comes through the pipe into the radbox but I can hear it trickle and run just fine, Anyways Ill put up some pics to make more clear my question, anything that is green I added today...
the ram is called jet-blue or something to that effect (and works about as well?)
Im about to go to the computer shop and have them look at it but saving $90 would be very worth it if you, the community, care to help :) although, i'twood be funny to see the computer guys intial impressions of the copmuter "Holy, S#@%":D
Oh and one more thing, feel free to ask me any questions that may help narrow down the failing component (even if its in the operator):rolleyes:
Well, it's hard to tell from the blurry pictures, but the first thing is that you can remove one of those SLI bridges. You only need one currently. Secondly, describe your issue in more detail. Specifically, what are you talking about in the BIOS? Am I to understand that after clearing CMOS, you can get to the BIOS but then the monitor goes blank while in BIOS? Or does it only fail to POST on boot up after you finished in the BIOS?
Also, save your money, most computer store tech guys aren't that great. Sure you can find some really talented people working in those places who could solve your problem, but more than likely you will get one of the 75% of those techs that are utterly inept and retarded.
follow Dan_D's suggestions.
Also, click out two of the ram sticks (im suggesting this because on AMD systems, 4 sticks CAN cause trouble :p ) just keep them isolated from the slot. no need to take em out of the loop
It normally doesn't on Intel chipset/processor based machines, although people assume it does because on the old i875P chipset based boards, you lost your 3% boost due to PAT being disabled with four sticks in use. This isn't really the case anymore, but four sticks can hinder overclocking efforts as your machine will be limited by the weakest module in terms of memory overclocking.
I'd swap all the ram out if possible. You might need to borrow some memory from someone or buy some from a store that will allow you to return it no questions asked. Sometimes a particular brand/model module won't work in a board at all.
The SLI bridges can be used two at a time and it doesn't effect the sli'ing belieb it or not, however I went ahead and removed one anyway and nothing changed. more details? Well it does seem to boot normally other then that one time i got the one odd message about cmos and timing. Now what happens is the computer boots as it alwase had except now it dies in the beginning portion of bios booting. Its not just a blank screen, the whole thing craps out. Also the crapping out occurs at slightly different times each boot (very slight), which could mean over heating mobo? My loop goes ram->mobo1->mobo2->radbox->res->pump. I know, its not the best was to setup a loop, but hey, its only cooling the mobo and ram, right?
Okay I will avoid geek-squad's 60$ waste, but givin that it is a very watercooled machine they might use their one good tech on it.
only problem is that the rams are paired via the blocks so straddling them acroos the 4 slots will be harder, but this is just an effeciency issue, maybe not compatability. I will try your suggestion first, I like it cause its simple :)
In light of this, luckelly I still have 3 gigs of 800 ddr2 corsair xms2 ram, imagine that! So, off to the testing I go
omg it was the freaking ram. thanks guys, back to newegg.com Will this project evar be finished?!?!
It didn't feel like a ram issue cause it would shutdown at different times durring the bios, and would get further with more idle time which resembles a heating issue with my newly installed mobo cooling. Thanks for the ideas!
Incompatible ram can produce a huge list of problems that will often look like what you might experience if another component was failing instead of the ram.
Have you got that Corsair RAM in there now?
okay it wasnt the ram, I put the corsair back into the machine, and it worked!, for a minute, and then it crapped out again. I tried to boot and now its acting just like the old ram crapping about instantly, and now that I think about it the other ram worked well the first time too. BAH it HAS to be a heating issue.
it is impossible for this not to be a heat issue cause it got all the way into windows and poo'ed there with both sets of ram, and that was the only circuitry I changed.:mad:
so, assuming its the coolent, I will explain my watercooling system in more detail below:
I am using a 120mm single 120mm fan radbox with a single pump for this loop. It goes, Pump-out (6mm tubing) ---> 6mm to 10mm adapter ---> 10mm to 2x6mm splitter ---> 2x RAM cooler (http://www.koolance.com/shop/product_info.php?cPath=29_56&products_id=251) ---> 2x6mm to 10mm combining y-tube ---> 10mm to 6mm adapter ---> northbridge motherboard block ---> southbridge motherboard block ---> 120mm radbox w/fan ---> reservoir (shown in pictures) ---> pump.
maybe the ram is too much restriction to put a little 6mm hose through before reching the mobo, if so, how should I change the loop to work more better. If however it sounds like "oh heck ya, that loop should be able to handle cooling all that crap, any order, no problem", my issue could be something else.. gulp, but it doesnt sound like it to me considering how the issue happens more early when the computer was just on.
I think it's still a RAM-related issue. 680i boards have been known to kill RAM, only i've never known for it to happen this quick. Heh, if this is true it's actually a motherboard problem because it's killing your RAM. Have you got another machine to try that Corsair RAM in to see if it still works? Did you try 2x 1GB or all 3GB?
Well, the thing is, I have not changed ANY computer components since I had it booting reliably a good hundred boots in a row. the corsair ram worked perfectly with this machine for so long, all I did was watercool (the green tubes) and add the new RAM.
I dont have another computer to test this RAM in, but it has been working so well for so long in this computer I can't imagine that now my pc has suddenly turned into a RAM killer since I watercooled the mobo.
I guess the main question is this, would an overheating motherboard cause the computer to just shut off? probably, right?
I know what you are saying, I too am often tempted to blame ram, but not when it has worked so reliably with this particular machine in the past.
If you look at the loop diagram I was mentioning you might notice that I am using 6mm hosing the whole way through, then I upscale to 10mm and split into two 6mm's which get even smalller via the ram heatsink.The problem here might be that the hose splitter is asking for 10mm input and I am only giving it 6mm of back-pressure, and THEN I am running it into the northbridge and then southbridge.
