If a display can have a custom resolution specified in the gpu control panel, why is variable refresh rate a make or break feature for some? Couldn't you just benchmark the title you're currently playing, exit, then set the custom refresh rate to the average fps of that title, then turn on vSync in game? Am testing this currently with Wolfenstein the New Colossus -- which allows you to set the max frame rate in the video settings in game -- the workaround seems copacetic.
Thanks.
Thanks.
