WintersFury
- May 19, 2007
Ok, so my system has an annoying fan in it. And about a week ago I thought I unplugged it, however the noise didn't die down much so I figured it was more than one fan. Having the time to dig through again today, I found that I had unplugged my cpu fan
However over the past week even with it getting in the mid 90's (F) here I had no clue. The computer is on pretty much 24/7 doing distributed networking stuff. So I check the temp of the cpu before I shut it off to plug the fan back in and it was only 52c at full load. Needless to say I was pretty amazed the temp was that low with no fan and no direct airflow over the HS.
Just figured I'd share that with you guys as I found it pretty amazing it was able to cool that well with basically no airflow.
