All the video cards are using PCB mounted ports seriously hindering airflow. But a dual slot video card has some 40mm across and that'd be aplenty for either a full sized DP or a HDMI connector across. Of course the cross section area would be the same but I believe a shorter but wider rectangle is better. So why is this not done?
