Why no auxiliary power connector?
I've seen other USB cards that have these auxiliary connectors. Those were just USB2.0 cards. I though USB3.0 ports supply more power than USB2.0 ports.
Well a pci-e x16 slot can do 75w of power. I don't know if a 4x slot does that much but even if it did half that it should still be sufficient for usb devices.
If the USB card was classic PCI it would need a power plug, but with PCI-E there should be no need.
Just got this card:
Asus U3S6
http://www.asus.com/product.aspx?P_ID=lGYmelQ8mJvPtYTv
It has two USB3.0 ports and two SATA III ports. Anyone have any idea why a card like this does not have an auxiliary power connector (4-pin molex, SATA, or floppy power connectors)?
Does a PCIe 4x slot provide more power than a PCIe 1x slot?
Yes, it does. See here (page 20).
1x = 10w max at startup, 25w max in use. But since your USB card was likely low-profile, it's maxed-out at 10w.
4x-8x = 25w max at all times (unless low-profile, then 10w max).
16x = 25w at startup, 75w max.
USB 2 with dual ports is dangerously close to exceeding the 1x card's 10w limit (max power per-port is a little over 2.5w, and you need a little extra for the controller itself), and 4 ports blows the power budget completely. Hence the reason you needed aux power with your old card.
So yes, there's no need for external power on a 4x card. FUNNY THING: the power pinouts are exactly the same for every card 1x-16x, so I'm guessing the reason they can supply more power is the increased number of ground returns.
