AlexStenka
- Aug 16, 2004
I was wondering what does low level format do and what is it for?
XOR != OR said:Actually, from what I remember from one of the zillion threads we have about this every now and then, you can't do a low level on current drives. It can only be done at the factory. You can zero out a drive, but that's not really a format.
Correct me if I'm wrong, but I seem to recall that IDE drives can't be low leveled by the consumer.
Low-level formatting is the process of outlining the positions of the tracks and sectors on the hard disk, and writing the control structures that define where the tracks and sectors are. This is often called a "true" formatting operation, because it really creates the physical format that defines where the data is stored on the disk. The first time that a low-level format ("LLF") is performed on a hard disk, the disk's platters start out empty. That's the last time the platters will be empty for the life of the drive. If an LLF is done on a disk with data on it already, the data is permanently erased (save heroic data recovery measures which are sometimes possible).
If you've explored other areas of this material describing hard disks, you have learned that modern hard disks are much more precisely designed and built, and much more complicated than older disks. Older disks had the same number of sectors per track, and did not use dedicated controllers. It was necessary for the external controller to do the low-level format, and quite easy to describe the geometry of the drive to the controller so it could do the LLF. Newer disks use many complex internal structures, including zoned bit recording to put more sectors on the outer tracks than the inner ones, and embedded servo data to control the head actuator. They also transparently map out bad sectors. Due to this complexity, all modern hard disks are low-level formatted at the factory for the life of the drive. There's no way for the PC to do an LLF on a modern IDE/ATA or SCSI hard disk, and there's no reason to try to do so.
Older drives needed to be re-low-level-formatted occasionally because of the thermal expansion problems associated with using stepper motor actuators. Over time, the tracks on the platters would move relative to where the heads expected them to be, and errors would result. These could be corrected by doing a low-level format, rewriting the tracks in the new positions that the stepper motor moved the heads to. This is totally unnecessary with modern voice-coil-actuated hard disks.
Warning: You should never attempt to do a low-level format on an IDE/ATA or SCSI hard disk. Do not try to use BIOS-based low-level formatting tools on these newer drives. It's unlikely that you will damage anything if you try to do this (since the drive controller is programmed to ignore any such LLF attempts), but at best you will be wasting your time. A modern disk can usually be restored to "like-new" condition by using a zero-fill utility.
Older hard disks required periodic low-level formatting by the system configurator or end-user. To facilitate this, low-level format utilities were created. These are small programs written to control the low-level formatting process for the hard disk. The hard disk controller would normally include one of these programs in a ROM chip in hardware, enabling access to the software without requiring any drives to be running in the system, and thus avoiding a possible "chicken and egg" quandary. In addition, more sophisticated, third-party utilities were available that would perform an LLF and also do other related features such as scanning for bad sectors or analyzing the drive to determine an optimal interleave setting. These would typically be loaded from a floppy disk.
Low-level formatting an older hard disk could be a rather complicated procedure, particularly for one who was not very familiar with PCs and hard disks. Various factors needed to be taken into account, such as defect mapping and setting the interleave factor. The particular conditions of the drive when formatting were also important: due to the vagaries of stepper-motor actuators, doing an LLF when the drive was very cold or very hot could lead to errors when the drive returned to a more normal temperature. Even the orientation of the drive when it was formatted was an issue.
As I have said (probably too often, sorry) modern drives do not need to be low-level formatted by the end user, and in fact cannot be LLFed outside the factory due to their precision and complexity. However, it seems that the need to LLF hard disks on the part of users has never gone away. Like some primordial instinct, many PC users seem to have a fundamental desire to LLF their modern disks. Maybe it is built into the genetic code in some way yet undiscovered. ;^) In fact, even if it were possible, the vast majority of the time that someone "needs" to LLF a hard disk today, it is not really necessary. Many users jump quickly to wanting to try an "LLF" whenever they have a problem with their hard disk, much the way many jump to re-installing their operating system whenever it gives them trouble.
Hard drive manufacturers have created for modern drives replacements for the old LLF utilities. They cause some confusion, because they are often still called "low-level format" utilities. The name is incorrect because, again, no utility that a user can run on a PC can LLF a modern drive. A more proper name for this sort of program is a zero-fill and diagnostic utility. This software does work on the drive at a low level, usually including the following functions (and perhaps others):
* Drive Recognition Test: Lets you test to see if the software can "see" the drive. This is the first step in ensuring that the drive is properly installed and connected.
* Display Drive Details: Tells you detailed information about the drive, such as its exact model number, firmware revision level, date of manufacture, etc.
* Test For Errors: Analyzes the entire surface of the hard disk, looking for problem areas (bad sectors) and instructing the integrated drive controller to remap them.
* Zero-Fill: Wipes off all data on the drive by filling every sector with zeroes. Normally a test for errors (as above) is done at the same time.
When most users today talk about "low-level formatting" a drive, what they are really talking about is doing a zero-fill. That procedure will restore a functional drive (that is, one that does not have mechanical problems) to the condition it was in when received from the factory. There are occasions when a modern hard disk can become so badly corrupted that the operating system cannot recover it, and a zero-fill can help in this situation. Stubborn boot sector viruses for example can be hard to eradicate without resorting to low-level intervention. Since the zero-fill cleans all programs and data off the drive it will get rid of almost any data-related problem on the drive, such as viruses, corrupted partitions and the like. Just remember that it's a bit like burning down your house to get rid of termites: you lose everything on the drive.
This type of utility can also be used to "hide" bad sectors by telling the drive to remap them to its collection of spares. Just remember that a drive that continues to "grow" bad sectors over time is one whose reliability is highly suspect. I discuss this matter in more detail here.
Warning: Only use a low-level zero-fill or diagnostic utility designed for your particular hard disk. You can download one for free from your drive manufacturer's web site. Even though damage probably won't result from using the wrong program, you may lose data and you may also complicate any warranty service you try to have performed on the drive. (Technical support people at "Company X" generally don't like to hear that you used a utility on their drive written by "Company Y".)
Warning: Always back up your data before you use a low-level utility, and make sure that you carefully follow all of the instructions provided.
Warning: Never run a low-level disk utility from within a multi-tasking operating system such as Windows 9x. Other programs running in the background could interfere with the utility. Restart the computer in MS-DOS mode first, or reboot the computer from a floppy.
djnes said:The funny thing is, like many other points these boards....despite the fact that it's correct, known, accepted, and factual, some people will come along and try to argue with you anyway.
AlexStenka said:What about killdisk I just used it and low loveled formated
djnes said:The funny thing is, like many other points these boards....despite the fact that it's corrent, known, accepted, and factual, some people will come along and try to argue with you anyway.
Ice Czar said:per request Im now including intermissions with my longer posts
valkyre said:Worried about someone getting your data? Smash your hard drive into a million pieces. Quick, easy, and fun!
