Why is XP Sp2 required for some program installations?
imzjustplayin
I don't understand, what specific feature is in SP2 that prevents the installation of some programs while that very same program can run under Windows 2000 with either SP3 or SP4??? From my understanding, SP1 came after SP3 and I believe slightly before SP4 for Windows 2000.
Yes XP SP2 supposedly makes it more secure (in my opinion, it just closes one hole and opens another..) but what specific feature would make it necessary in order to say run a game? Or run AVID? ???? Is this just like the PSP updates where the games force you to update your ROM so that your homebrew applications don't work anymore? A way to force me to upgrade to something because they believe "it's good for me"? Or is there something specific in this SP that they need? ......:rolleyes:
I don't use SP2 because 1. My system runs fine with out it 2. I don't need the software firewall as I have a hardware firewall and nagging about not having this and that enabled and 3. I have compatibility issues with applications I use.
At this point in the game there really is no reason not to install SP2, windows firewall can be disabled if it bothers you that much. Considering the service pack is free I doubt they are trying to force anything on you at all, SP2 did really clean up a lot of stuff though.
Doesn't microsoft have a more comprehensive list of changes in SP2? I'd really hope that there is more to SP2 than just a culmination of updates after SP1 and before SP2.
  • When you install SP2 on your Windows XP-based PC, you can feel confident that you're running the most secure Windows operating system available. You'll be supported by innovative features and default safeguards that will increase your overall security levels significantly. For example:
  • Take control with Windows Security Center. When it comes to managing your Windows XP security settings, the new Windows Security Center is your command central. At a glance, you can monitor your current level of PC protection, including: firewall status, automatic update settings, and virus protection.
  • Help protect your PC with Windows Firewall. Turned on by default, the new, built-in Windows Firewall helps defend your PC against viruses and intruders who try to access your computer over the Internet.
  • Block distracting pop-ups in Microsoft Internet Explorer. Now you can stop most browser windows that Web sites pop up without your permission, giving you more control and less interruption when you're browsing the Web.
  • Avoid harmful communications with improvements to Outlook Express. E-mail is a great way to share photos, links to interesting articles, and other attachments. But some attachments contain viruses that wreak havoc on your system. Outlook Express now supports a new Attachment Manager which isolates attachments as you open them. This prevents the opening of unsafe attachments which can infect your system with a virus or worm.
  • Go wireless more securely. If you have a wireless network, or if you connect to the Internet at coffee shops or airports, the improved wireless support offered in SP2 simplifies the process of discovering and connecting to wireless networks.
  • In addition to significant security-related enhancements, SP2 also offers Microsoft's latest hardware and software innovations. These new drivers and updates will help you use Windows Media Player, Microsoft DirectX, and emerging standards such as Bluetooth technologies more safely and effectively.
None of those things affect me in any way. I don't know about the Direct X part as I've got 9.0C, dont ever want to use media player 9+.
Again, none of those things help me in any form, so far I've just downloaded the small updates and security patches.
Yes. http://go.microsoft.com/fwlink/?LinkId=28022 has more detail about the changes and implications of such changes.
SP2 and its security features changed the way some programs interact with the OS. Just as some programs written previously do not work with SP2 (which for some delayed roll-out to ensure adequate time for testing), newer programs might not work without it.
I'm still surprised at the amount of computers I work on that don't have SP2.
I just don't know what people's problem is upgrading, it's free, more secure, and widely supported. Just the general, misinformed public that can care less I guess- it can drive a person nuts ;)
As per your Q, PS2 is just widely accepted as "standard" now. Programs that need it, are designed to work with the new security enhancements (like ports through Windows Firewall, for gaming). There is really no reason to not upgrade.
And you're just as ignorant for thinking that one does not pay a price for upgrading to this newer service pack.
http://www.microsoft.com/downloads/...d7-b791-40b6-8364-685b84158c78&DisplayLang=en
Changes to Functionality in Microsoft Windows XP Service Pack 2
Microsoft Corporation
Published: September 15, 2004
Authors: Starr Andersen, Technical Writer; Vincent Abella, Technical Editor
In Microsoft® Windows XP® Service Pack 2, Microsoft is introducing a set of security technologies that will help to improve the ability of Windows XP-based computers to withstand malicious attacks from viruses and worms. The technologies include network protection, memory protection, safer e-mail handling, more secure browsing, and improved computer maintenance.
Together, these security technologies will help to make it more difficult to attack Windows XP, even if the latest updates are not applied. These security technologies together are particularly useful in mitigation against worms and viruses.
This document specifically focuses on the changes between earlier versions of Windows XP and Windows XP Service Pack 2 and reflects Microsoft’s thinking about Service Pack 2 and its implications for developers. Examples and details are provided for several of the technologies that are experiencing the biggest changes.
Contents
Part 1: Introduction
What’s New in This Version
Abstract
Other Resources and Feedback
Legal Notice
Component Sections
Scope of This Document
Overview of Windows XP Service Pack 2 Security Technologies
Part 2: Network Protection Technologies
Alerter and Messenger Services
What do the Alerter and Messenger Services do?
Who does this feature apply to?
What existing functionality is changing in Windows XP Service Pack 2?
Alerter and Messenger Services Disabled
Bluetooth
What does Bluetooth do?
Client Administrative Tools
What do the client administrative tools do?
Who do these features apply to?
Remote connectivity
DCOM Security Enhancements
What does DCOM do?
What new functionality is added to this feature in Windows XP Service Pack 2?
Computerwide restrictions
More specific COM permissions
What settings are added or changed in Windows XP Service Pack 2?
TCP/IP
What does TCP/IP do?
Restricted traffic over raw sockets
Limited number of simultaneous incomplete outbound TCP connection attempts
Winsock self-healing
New Winsock Netsh commands
RPC Interface Restriction
What does RPC Interface Restriction do?
RestrictRemoteClients Registry Key
EnableAuthEpResolution Registry Key
New RPC Interface Registration Flags
Do I need to change my code to work with Windows XP Service Pack 2?
WebDAV Redirector
What does WebDAV Redirector do?
Disabling Basic Authentication over a clear channel
WININET: Disabling Basic Authentication over a clear channel
Windows Firewall
What does Windows Firewall do?
On-by-Default
Boot time security
Global configuration
Port restrictions
Command-line support
“On with no exceptions” operational mode
Windows Firewall Exceptions List
Multiple Profiles
RPC support for System Services
Restore Defaults
Unattended Setup support
Enhanced multicast and broadcast support
Integration of Internet Connection Firewall and IPv6 Windows Firewall
Updated Netsh Helper
Updated user interface
New Group Policy support
Outbound connections
Unsolicited inbound connections for applications
Inbound connections for services
Inbound connections on RPC and DCOM ports for System Services
What does Windows Media Player do?
Windows Media Player 9 Series
Windows Messenger
What does Windows Messenger do?
Block Unsafe File Transfers
Required User Display Name
Windows Messenger and Windows Firewall
Wireless Provisioning Services
What does Wireless Provisioning Services do?
Wireless Network Registration Wizard
Wireless Network Setup Wizard
What does Wireless Network Setup Wizard do?
Part 3: Memory Protection Technologies
Data Execution Prevention
What does data execution prevention do?
What new functionality is added to this feature in XP Service Pack 2?
Data execution prevention on 32-bit versions of Windows and applications
What works differently?
Application Compatibility
Driver Compatibility
System Compatibility
How do I resolve these issues?
Part 4: E-mail Handling Technologies
Outlook Express
Plain Text Mode
Limit External HTML Content Downloads
Attachment Execution Service API Integration
Part 5: Enhanced Browsing Security
(In order to make this fit into one post, I had to trim this down a bit, but if you care, you can check out the Microsoft site and download the ‘00_CIF_Front.doc’ file which has this table of contents in its entirety.)
Basically it’s 3 pages worth of security ‘enhancements’ and changes for Internet Explorer, yes 3 pages. Internet explore really has that many holes, which explains why so many machines got infected so easily… But if you don’t use Internet Explorer anymore, it’s really a non issue.
Part 6: Computer Maintenance
Filter for Add or Remove Programs
What does the filter for Add or Remove Programs do?
Filtering out updates from the Change or Remove Programs list
Microsoft Windows Update Services and Automatic Updates
What do Windows Update Services and Automatic Updates do?
Support for Applications and Hardware Drivers
Support for Additional Update Categories
Automatic Prioritization and Download of Critical Updates
Client Side Targeting
Scriptable APIs
Automatic Detection, Download, and Installation
No Interruption During Update Installation
Install Updates at Shutdown
Extensible Management Capabilities
Background Intelligent Transfer Service (BITS)
Scheduling and Notification Options
Self-updating for Client Computers
Improved Update Applicability Rules
Resultant Set of Policy
What does Resultant Set of Policy do?
RSoP Use with Windows Firewall Enabled
Administering Remote RSoP with GPMC SP1
Administering Remote RSoP with the RSoP MMC snap-in
Delegating access to Group Policy Results
Remotely editing a local Group Policy object
Security Center
What does Security Center do?
Registry settings
Group Policy settings
Setup
What does Setup do?
Package Installer for Windows
Windows Installer 3.0
What does Windows Installer 3.0 do?
Patch Management Support
Smaller & Reliable Patches
Patch removal
Source List support
Sequencing
FTP and GOPHER is no longer supported
Windows Installer service is no longer interactive
Windows Update
What does Windows Update do?
Updates for Microsoft Applications
Express and Custom Installation Options
Windows Update and Microsoft Update Home Page
Content Organization and Navigation
Supportability
Part 7: Other Technologies
NetSchedule and Task Scheduler APIs
What do the NetSchedule and the Task Scheduler APIs do?
Tightening RPC security in the Scheduler service
Tablet PC Enhancements
What do the Tablet PC Enhancements do?
In-Place Tablet PC Input Panel
Context for Handwriting Recognition
Latin alphabet based recognizers: Improved Recognition Rate
Latin alphabet based recognizers: Improved Recognition for Single Characters
Latin alphabet based recognizers: Language Lexicon Improvements
Latin alphabet based recognizers: Improved Recognition of Delayed Strokes
French recognizer: Better Recognition of Characters with Diacritics and Ligatures
French recognizer: Conforms to French Spelling Reform
German recognizer: Better Recognition of Umlaut characters and “ß” Character
German recognizer: Improved Recognition Rate for Compound Nouns
German recognizer: More Post-reform Spellings Added
Lined and Free Mode Support for All East Asian Languages
Cursive support available for all East Asian Languages
Recognition improvements for small and large Katakana and Hiragana characters
Added characters frequently used in Japanese names
Recognition improvements for data elements
Microsoft Data Access Components
What do the Microsoft Data Access Components do?
What existing functionality is changing?
Controlling block storage devices on USB buses
What does controlling block storage devices on USB buses do?
Distributed Transaction Coordinator
What does Distributed Transaction Coordinator do?
Securing all network communication by default
Internet Information Services
What does Internet Information Services do?
Internet Information Services Configuration Options
Part 8: Conclusion
Conclusion
Appendix A: Document History
Appendix B: Group Policy Administrative Templates
Reading through that should prove that SP2 'security updates' are merely just extra "hand holding" in an attempt to prevent the user from screwing up their system, unfortunately, all it does is make them hit ok to everything they see so they can continue doing what they want to do..
In short, there are the things I don't care for/especially don't want that come with this service pack.
The only thing I could care about is the bluetooth capability but I find it irrelevant because for now, I can find my own bluetooth stack with the hardware I have, therefore not having to use microsoft's POS excuse for a bluetooth stack..
The NXbit (DEP) thing is useless on my machine and I don't care to have it even if I could use it.
I don't like how they reinstalled windows messenger back into the OS after I went to the trouble of removing that pesky piece of malware.
I especially don't want media player 9, one word; DRM.
I don't like the fact that it limits the number of connections to the machine.
I don't like how they replaced the way WIFI works in SP2, the original implementation is better/less annoying since if I have my own software, I simply doesn't bother me and if I don't, it's easier/better to use than the SP2 implementation which I find to be incredibly naggy and annoying
I don't like the wireless network setup wizard, just unnecessary.
The Security Center and Windows firewall combined are the ultimate nagging program to be incorporated into an OS. It just encourages the user to hit OK to everything. Not to mention the additional wasted ram..
Half if not the major purpose of this SP is to fix the problems associated with internet explorer/outlook, which I refuse to use so it's really non issue.
Windows Installer 3.0 can be downloaded separately so it's not necessary to have SP2...
DCOM security enhancements can be had separately from this SP so it's not necessary to have SP2 for this either.
MDAC updates can also be had separately, therefore not requiring SP2 once again.
The RPC Interface restriction "fix" can be had via a patch, it is not necessary to install SP2 in order to fix this security issue, which was the cause of all those systems DDOSing the windows update site back in august of '03.
http://searchsecurity.techtarget.com/originalContent/0,289142,sid14_gci917452,00.html
Therefore the fix of this huge security hole which infected even my machine (because all you needed to do was be connected to the internet) can be had via a small patch, you do not need SP2 for this either.
Background intelligent downloader, used for windows updates, once again can be had, withOUT having SP2 installed as this is downloaded when Windows Updates/Automatic Updates is run.
DTC, I don't see how this could have an effect on any user of this forum, this is mostly an administrative 'fix' meant to plug any security holes when implementing policy via DTC.. So unless you're machine is some terminal on some school network, this should be non issue..
RSoP, again another administrative addin/fix that doesn't apply to typical users.
Tablet PC enhancements don't affect me in any form.
IIS update, who cares? Anyone who uses IIS IMO is an idiot, there are much better third party applications out there for the same function, not to mention that IIS is a security hole in itself.
Couldn't care less about the Task scheduler update..
So tell me, what exactly does SP2 that I should go and download for? By from what I've read, it has only confirmed my beliefs before that SP2 adds a whole lotta crap that I don't want and breaks compatibility unnecessarily. Microsoft can't even explain to me why some of my applications don't work in SP2 anymore, planned application obsolescence? Having secret deals with certain companies? who knows! But what I do know is that SP2 is a whole lotta crap and from my experience, has not reduced the number of cries of help from SP1 and if anything increased them... And if you're going to argue that there are far more updates to SP2 than this, then why didn't microsoft say so? Do they have something to hide? I wouldn't be surprised.. And if this is true, why would I install something that doesn't specifically tell me everything it's going to do?
Can I throw a little logic in here for a second? If you really have a problem installing SP2, despite that fact that it's the standard platform right now for XP (and has been for going on what seems like 2 years now), why are you in here, copping an attitude? Why aren't you spending your efforts going to the 3rd party who created the software that requires SP2 and asking them WHY IT IS NECESSARY?
Seriously, I can't tell you why software requires it, but the developers sure can....so why are you posting a thread about it, and then handing shit back to anyone who posts here? You seem to know all about SP2 and what it gives you....so take that to the developers of said software and question them!
I'm declaring common sense official dead. I'm not trying to say you're wrong to complain. I'm saying to use your head and direct that frustration to the proper channels.
What I notice, is you didn't even continue on the discussion you started.
You instead try to flame me with all the reasons SP2 sucks.
Starting a thread- knowing what is going to be said, and then replying to those comments is considered trolling.
Do you really see a need for a post a mile long? If I want to read about SP2 features I can go to Microsoft's website and read about them- I don't need to read this spam.
As djines said- if you know everything about SP2, stop griping about it. Your post was asking WHY SP2 was required.
You are crapping on your own thread.
WHY is SP2 required? I attempted to answer it, but you blew me off and instead posted all the reasons why you don't like it.
You can install it or not, choice is yours. But if you want to know why certain apps won't work with or without it, then you have to contact the developer to get a straight answer on that one. I'm not sure what kind of answer you expect.
Basically service packs are big OS updates. these updates have fixes, enhancements and add new features to the OS. wile most of this is backwards compatible for old applications in order to use the new features and enhancements developers must program for a level of service pack. This makes the software require a level of service pack in order to work.
Pirate maybe? Only reason I can think of, if your that afraid of Microsoft and their updates, should you be using windows?
Yes but when the only compatibility is with windows, you're forced to use it. I try to avoid updates that are unnecessary as much as possible.
Things like Windows Media Player 9, Security Center, WGA crap are things I'd avoid.. I'm going to avoid vista as much as possible and hopefully I'll never have to install it on my main machine.
Some day you will have to, as XP will become out dated and most of the software you currently use will require Vista or something higher as they are updated. this is not to say you are welcome to stay with what you have as long as you can stand it, hell with that kind of stance it's a wonder you ever left Windows 95 or even DOS.
