Why is my temperature so high??
SquallRealm
When i first got the pc, it was all fine, running 35C idle and 42 in games.
Ever scince i overclocked the temp is at 50C, even when i reduced to stock.
Is it possible that just my temp readers are screwed up? because its around 38 when
i go into the bios...
might be dust buildup (depending on how old the PC is)
you'd be surprized how much of a diff they can make
SquallRealm said:
whats a good prog other than MBM to see temp?
if you got an ASUS I know they have a util for that, you can download it from their site
msi k8n neo2 platinum
and no its not old.. less than a week old.. i think the sensor is just fucked up.. can anyone tell me if i can buy a new sensor?
Did you increase the voltage when you overclocked? Maybe you forgot to set it back down to stock when you clocked the processor back down.
