I just put together a machine for someone and I've run into some trouble I'm hoping you fine folks can help me out of.
Here's the system in question:
Q6600 (stock cooler, no overclocking)
MSI P6N SLI Platinum
2x2GB G.Skill PC6400
512MB Radeon X1650 Pro PCIe
(2) 320GB Western Digital (reused from old build)
500w Sunmax PSU (reused from old build)
Generic PCI USB, Firewire800, and Serial Cards
Belkin Memory Card Reader
I got the system assembled, installed Windows XP, loaded drivers, patched, etc., etc. It wasn't until after all that, when I tried to copy some backed up data from the secondary drive to the primary/OS drive, that the system crashed with a BSOD.
STOP: 0x00000003 (0x000000F4, [varies], [varies], [varies])
I tried again with the same results each time. After a while, Event Viewer reported an error reading data from the secondary drive. I switched the drive to another port and thought for a while the problem was solved... until it crashed again after copying ~45GB.
The only other error in Event Viewer during all this is about the parallel port service failing to start, which I believe is somehow related to the "Unusable Parallel Port" installed as part of the 2-port serial PCI card.
A reinstall of the onboard SATA drivers again led me to believe the problem was solved, as I was able to copy ~120GB without issue. I decided to fire up Orthos while I copied some more data, just to put the system through its paces (the system is not and will not be overclocked). A few seconds in, the system locked up solid.
Through much trial and error I've learned the following: two instances of Orthos (with affinity for two cores each) and moving data results in the computer locking up inside of a minute. Running one instance of Orthos while copying, or two instances without, also locks up the system, albeit after a slightly longer period (up to 20 minutes). One Orthos instance or copying by itself works for longer still (a transfer of ~150GB was able to complete), but I can't very well give this machine back to the poor guy with a stipulation that he never multitask.
EDIT: Both Orthos and Prime95 v25+ yield similar results.
Heat does not seem to be an issue, since both the CPU and northbridge temps are well within reason. I threw in my PSU (Antec 480w NEO... Sunmax doesn't inspire much confidence), but it changed nothing. Memtest checks out, though I only did a single loop. Frustratingly, I don't have the parts to swap out (CPU, MB, RAM) to properly diagnose the problem. My assumption would be a bad motherboard, but I thought I might get a few opinions before I decide it's conclusive enough to start an RMA.
Thoughts?
EDIT: Also, as an aside, I'm confused by PAE. I thought PAE was only used for over 4GB RAM, yet it's active on this computer. System Properties also reports only 3GB... is that because of PAE or should I be looking at that as a symptom of the above issues?
Thoughts?
