Old photo, now just running distilled water + liquid utopia. Also, flipped the ap181's to the top of the rad.
Pump is a d5 vario on 4 and the 180mm fans are on 600rpm.
Cpu is 53 deg idle, 80deg temps in prime95 small fft running a 1.33 vcore.
Gpu is a gtx670: 36deg idle, 70deg load.
Not enough rad?
Clogged EK block?(might check soon)
Too many blocks?
Expecting too much from x58? (used a 950 and a 920)
