well my pc works fine, webpages load super fast, fast DL speeds, etc.
my other PC which is also wired is slow. takes like 1 minute to load footlocker homepage.
my main PC is DLing always at about 100-300 KBps off BT. usualy even slower then that. I caped my UL for bittorent at 35Kbps. my laptop thats connected on wifi is fast too.
the router iam using is a D-Link DI-524
my PC has integrated NIC and the other PC has a 3com, i swaped the NIC about 3 times still same result even changed the ethernet cable that runs to the other room. i was thinking of getting a wifi card for it and see if that would improve the results. is that my last option?
