Hyper 212 will be not louder when using 120fps? Which version to get for Hyper 212? I'm using Gigabyte GA-H77M-D3H motherboard.Load (in game) causes the CPU to scale which requires more voltage which causes more heat. Get a hyper 212 for cheap and call it a day.
that cooler is better than stock intel cool so it will cool better and be quieter.Hyper 212 will be not louder when using 120fps? Which version to get for Hyper 212? I'm using Gigabyte GA-H77M-D3H motherboard.
How about Cryorig H7?that cooler is better than stock intel cool so it will cool better and be quieter.
stock cooler is a POS
what is your PC specs first?How about Cryorig H7?
What PC specs information do you need?what is your PC specs first?
anandtech and techpowerup have great reviews on heatsinks. noctuna D15 is the best but super premo. That evo 212 is a decent cheap heatsink
if your runnign stock there is no reason to get a D15.
if you want true silence just look at techpowerup reviews at volume levels
But I want 120fps for FPS games because of smoother gameplay.You're monitor is 60hz set in game to 60fps.
Sure reads like a troll. You don't post these questions on hardforum.com. You post them on a computers for dummies forum. *No offense to op if not a troll.Either this guy is really new or a troll.
Sorry I'm really new. So you mean there is no need 120fps for playing FPS games and 60fps is enough? I have delay mouse movement by using Logitech M100 when using 60fps. Is it because of the mouse?Either this guy is really new or a troll.
How about Cryorig H7? Is it better CM Hyper 212?If your monitor is 60hz, then there rarely is any point in going over 60fps. But, sometimes more fps makes the mouse feel smoother on some games. Turning off v-sync may help as well.
Changing to a better cpu cooler will make your pc quieter too.
again check anandtech and techpowerup reviews. That will give you the best info.How about Cryorig H7? Is it better CM Hyper 212?
