Okay...
So, I just built my first comp. Athlon 64 3200, Lian Li PC-65, Corsair XMS 1GB PC-3200 RAM, Antec TruePower 480, 70GB Raptor, Asus K8V Deluxe.
I'm not oc'ing anything. Everything is at stock speeds. The fans in the case are the stock fans that came with it.
Idle, it's about 38 C. Load (under Prime95 after 1/2 hour) it's at 53C.
I don't understand why it's so hot?? Initially I was using the stock HSF. Didn't like the noise, so I bought a Zalman 7000. Which is great -- VERY quiet -- but now I'm getting these temps. Before it was about 38 idle, 50 load too.
Anyway, I thought before my problem was that I gooped on the thermal grease. So, this time I spread it super thin all over the CPU, and didn't put any on the HSF. It was very very thin, and only a slight sliver here or there not covered.
But, my temps didn't go down at all. My case looks like a bowl (box) of spaghetti -- the wires are everywhere. But could that cause it to get so hot? If so, how do I get them all out of the way?
Need help! Thanks in advance to all -- this has been a super helpful board.
