thenixhex311
- Apr 30, 2005
I just finished setting up my system last week, and ran 3Dmark05 and came up with a score in the 7589 area (I had it to 8000 something too once) area for my system. I had my 3700+ running at 2.4ghz and the voltage to 1.45v.
I lost power last night due to a storm and somehow reset my CMOS, and had to change all the settings again, this time I OC'ed my processor some more to 2.6ghz and 1.5v, now when I ran 3dMark05, my score was 6246.
Why is my score 2400 points lower? Ive read some people saying they have 7800gtx's in SLI at 12000 or so, so 6200 seems 'right' but before I had it at the 8600 area. My GPU is OC'ed via nvidia overclocking to the numbers in my sig, as it was before.
What would/could be wrong that I'm seeing this drop in score?
The extra heat on my CPU? What settings do you run 3dmark05 at to get these scores?
I typically just left it at 'default'
Another 3DMark05 question, once you get past the first 3 video tests ( guys with guns, in the forest, and the airship/monster) and it does the CPU test, is it normal for the video quality on the CPU test to be crappy and average around 2-5fps?
What the hell am I doing wrong with my setup and what could be causing this drop in 3dmark05 scores? thanks for the help.
And should I be unsatisfied with a 6xxx score, what is an 'acceptable' score for a 7800gtx and my setup?
thanks, again
thanks, again
