Why is my 280 a wuss?
Ok i just built my new rig... q9550, bfg 280, and 4gb of pc2 8500. However, when i try and run Fallout 3 on Ultra, or even high, i get only about 15 fps! I should be around 60 fps i installed the newest drivers, I even turned off AA but when i boot it up it is as jerky as a crack addict in withdraw :confused:
Check your GPU temps. It could be one of those 280's that are overheating and throttling.
I can run fallout 3 at 60 fps with ultra settings at 1080P with my 280.
Yeah something is seriously wrong. I'm often getting 60 FPS with my OC'd GTX 260 on XP (and its smooth as silk).
Have you tried a clean boot? Disable sound? Cleaned out the old drivers with DriverCleaner Pro or Driver Sweeper (in case there's a conflict of some kind)? Checked your case, CPU, GPU temps?
