Why is GPU core clock cutting itself in half?
Coldblackice
I'm using Afterburner to "natively" overclock a 7950, having used the "-xcl" option. From what I understand, this bypasses the need for unofficial Afterburner overclocking, and instead unlocks the limits through Catalyst Control Center, which CCC then manages/controls.
The problem is that although I have an overclock setting of 1150mhz core clock, after a little while in-game, it drops down to around 750mhz, constantly fluctuating up and down a few mhz. I'm guessing this has something to do with AMD's PowerPlay?
I've tried closing down CCC and MOM to stop this, but it continues to happen. I have to continually alt-tab out of the game, reapply an overclock in Afterburner, alt-tab back into the game, and start playing again. But it's only a matter of time before the core clock gets clocked back down to a constantly changing core clock. I have no idea why this is happening, or what the mechanics of PowerPlay are.
How do I stop this from happening? It severely kills performance. It's done this so far in Starcraft 2, and also Far Cry 3.
Sounds like thermal throttling. What are your GPU temps when this happens?
doesnt thermal throttling start by taking away 7mhz at a time not half? atleast thats how it works for nvidia cards.
i know ive had this issue a ton when playing dota 2. found out it was caused by the "adaptive" power performance setting, i switched it to prefer maximum and never had an issue again
are you playing in window mode on your games? check your profile to make sure it looks good, post it here.
Make sure temps are ok, you can turn off AMDs overclocking profiles and just use MSI afterburner to force it. All it sounds like is a conflict. What driver version do you have?
I've never had great success with AMDs own overclocking/power management tools.
Mid 70's. Seems like that wouldn't be hot enough to warrant throttling, no?
Is that "adaptive power performance" setting an nvidia thing? I can't remember seeing that anywhere in the AMD side of things.
I've tried both fullscreen and windowed fullscreen. Same thing.
PS - Is there any functional/effective difference between using fullscreen vs windowed fullscreen? I've never known why one would choose one over the other. They always seem to give equivalent performance.
Temps seem to be fine, hovering in 70's. Where do turn off AMD overclocking profiles?
I'm using 13.3 Beta 3.
yeah, there is a profile hidden in one of the files. I'd do a driver sweep and reinstall.
Is there a way to remove the profile manually, or at least so I can see where it is for future reference? I'd like to get at the core of this issue, rather than just reinstall and hope it goes away.
There's something distinctly wrong going on here. It's uncanny -- no matter what settings or overclock I use, it keeps dropping back down to around 700-750Mhz core clock. Unbelievable. It's making me angry.
GPU temps are hovering at 58-60 degrees. Power is at 1.25. Core clock is set for 1150, but I've also tried backing it down to 1000mhz, and it still downclocks. Memory was set at 1700, but also contributes to the core download if I set it to 1500.
EDIT:
There's some kind of dumbass timer mechanism involved here. I just kept reapplying the overclock each time after it'd get downclocked, and it's clear to see that it's based on some kind of timer mechanism -- no amount of temperature or game setting or overclock setting is affecting it.
Hell, I even reapplied the overclock and then let Far Cry 3 continue to wait in the options menu, without doing anything. Sure enough, the card downclocked after the exact same time interval as before.
Another oddity -- GPU-Z isn't showing the correct downclock. GPU-Z shows that the card does downclock, but that it jumps down to a static, unchanging 850Mhz. Perhaps this is merely a conflict of Afterburner and GPU-Z trying to report at the same time. However, GPU-Z is able to know and report when the clock is up at 1150Mhz.
There's some funky kind of throttling going on here -- and I'm wagering it has to do with the bios.
It keeps downclocking back down to 850mhz (what GPU-Z and CCC report). Googling around finds others who are getting downclocked to this same speed, which appears to be stock speed. It seems to be some sort of power issue, like PowerPlay isn't behaving correctly.
Is PowerPlay configurable in the profile?
EDIT:
Well, I'll be DAMNED.
It was the stupid "Power Control" setting. Even thought it was at a full +20% in Afterburner AND in CCC, it still seemed like it was causing the issue. I cut it back down to 0%, played for a little bit (overclock wouldn't work, period), then reapplied a +20% power increase and a fresh overclock. And now the little bastard is holding steady without any downclocking whatsoever -- solid for 2+ hours.
Phew! No idea why Afterburner is reporting that it's applied the +20% increase, even though it apparently hasn't. I suppose I'll just have to manually unapply and then reapply it every time I boot (unless anyone has any suggestions/ideas).
