I'm running a Samsung Syncmaster 955df and a Radeon 9800pro. For some reason 16x12 is broken: I cannot view the whole image. The right side extends past the edge of the monitor to such an extreme that I have to guess at the menu options of most games, and the windows desktop is unusable. If I use Fraps to capture a screenshot the resulting image appears correct, which leads me to believe it's a problem with the monitor. No amount of adjustment to the monitor controls can fix it; the resize and re-position options only work on the visible area. Has anybody ever seen this before?
thx,
-Ace-
thx,
-Ace-
