Exactly, it came about becuase of that other lovely bit of marketing hype: "HD Ready". As many people know the "HD Ready" specification is something like this:brentsg said:The "trueHD" thing is just marketing at work.
WildSide said:I think most are missing the big picture here, 1080progressive is superior to 1080 interlaced and fair warning concerning the technology has been out for some time now however one has to do a compareson between the terms Progressive vs. Interlaced![]()
A 1080i screen (there are not many) would look very bad used with a computer because of the interlacing. Also the size of the screen must be looked at in relation to viewing distance otherwise you shouldn't draw such conclusions.Blauman said:depending on the size of the screen its sometimes damn near impossible to see the difference between 720p, and 1080 i/p. With a 37" LCD TV 720p will look just as good as 1080i/p IMO, but a 720p screen will not look as good as a 1080i/p screen if used with a computer.
Do you mean the screen resolution or the source material?figgie said:not one person would be able to tell if it is 720p or 1080i or 1080p at anything below 46 inches.
False.figgie said:in a double blind test
so is it better? higher number is not always better![]()
artmonkey said:The photo has been processed
The image on the screen has been interpolated via the photo
apology accepted.artmonkey said:Yeah... and the rest, you realise that when I say processed, I mean by the camera, not by you.
