Eman D. Rahym
- Mar 23, 2012
It really took you a couple of weeks to do that?OK, so after a couple weeks of fiddling, I have Windows 8 to the point where I very rarely need to go to the Start Screen. The only things I have on there are the Desktop, Weather app and a group for utilities, nothing else. I think I've finally reached an acceptable compromise with it now. I've also done a similar setup on my wife's PC, and she's not complaining about Windows 8 nearly as much anymore.
So my opinions is, once you get all the Metro crap out of the way, Windows 8 is actually a pleasure to use. Just wish I didn't have to do all that work to get there!
Huh.
Of course, since you hardly ever use the Start Screen, does it really matter whether or not you only have a few apps pinned to it or a bunch of apps pinned to it? I don't understand this mania to make the Start Screen empty. As long as you are using the tool, what's wrong with using it the way it was intended? Why not just pin the apps you use the most in one group and then put all the rest of the stuff off to one side? And if you don't know how to create groups in the Start Screen, don't spend another two weeks thrashing around with it. Post on the board and I'll be glad to help you out.
