Why don't 'they' provide proper comparisons
I think it's pretty simple, their is the Z, H, and P groupings. 77 and 67 depending on when you buy. If I was buying now that would narrow me down to the Z66 line, and based on price I and form factor a maximum or 2-3 choices. When most people ask for motherboard advice they usually ask for the best board at a given price point. Comparing between brands is much more difficult than within a brand.
So let's take H61 as an example: 29 choices!
How am I going to compare those?
you have to look at all the features, board sizes.. each chipset has its own set of features, find the one you like that narrows the choices down.. then your price point like silk said, and that narrows your choices even more.. from that point you can start comparing the boards that fit within your choices.
personally newegg + advanced search solves everything. why? because most of the boards on gigabytes site aren't even made anymore and have been replaced by other boards.
So the Gigabyte site itself is useless for comparing models. That just sucks.
ok heres how you compare.
GA = Gigabyte
H67 = Chipset
PH67 = H67 with no onboard video (like a p67, h67 hybrid)
H67M= Micro ATX
H67A= Back USB3 ports
H67N = Itx
so H67MA = Microatx with back usb3 ports.
UD = ultra durable.basically better vrms and pcb.
B3 = B3 stepping. Non B3 boards arent available anymore.
They all suck and are overclocking-locked..well..they're good for basic computering..nothing else.
Look @ p67-z68-z77 for overclocking
I had the biostar h61 mgc..nice little board
All of the only slightly different models that are available now drive me crazy! Granted, I like having some choice, but it just seems like the companies are causing confusion on purpose, especially when the differences are so minor. =(
