greasedneut
- Aug 16, 2004
I bought 2 of the Zalmam Mic's w/ Clips and both of them won't register any sound, I believed it was highly unlikely both were failures, so i can think we can assume that it's a sound card problem. i'm relatively sure i have it plugged in to the correct slot, the very left on that image I posted. I used to have a working headset which I just plugged in to see if it would work; and it didn't either, but it used to work before I re-formatted.
Sound card is in Sig, I'm running 64 Bit Vista with updated drivers...
