Why does this happen?
Dallows
Why is it that with my luck I always have at least one mobo/case combo that the led on the front don't have the correct matching spots, or whatever you want to call them on the mobo so you can have a fully functional case with working leds for hdd and power? Is it just me?
Ive personally never had both the power led and hdd led working at the same time ever. Although I hoping to remedy this with a suggestion I read on here of flipping the connector around.
well, in my case the power led, or is it the hdd led? can't remember, either way, one of the two fits fine, I guess it's just backwards, but with the other the connector is all wrong, it has 3 in a configuration like this 1 0 1 whereas 1 = connector and 0 = nothing, just a spacer. On the mobo the connecting pins are two next to each other, so the other way would be to take apart the case connector. pain in my ass. why can't the good people of the computing industry join hands and make this simple and easy on everyone by making that stuff standard.
You can always pull one of the pins out of the socket and make it 1 1 0 and then fit it in.
Some motherboards like the Intel ones have an alternate power LED connector that has the 1 space gap in the center, you can either use it or the one in the cluster.
