Red Squirrel
- Nov 29, 2009
I've been having wifi issues with my Playbook since day 1 and since I installed a unifi it's a bit better. Then it occured to me, it's any time the packets need to go through my pfsense firewall where it sucks. When I changed state table optimization from aggressive to conservative it helped a little. But putting it to normal did not help more. Normally the connection stops, drops, slows down, etc. For example, youtube. I can load a movie maybe about half way then it conks out. I cannot load intensive sites that have flash. The only way I can use youtube is the built in app. the site itself barely loads if at all. Meanwhile I can stream something from my local servers fine. Everything local is fine most of the time. If I connect TO my pfsense box, half the time I just get a network error and have to keep refreshing till the page finally loads.
I'm starting to think for some reason the playbook does not like pfsense. Has anyone ever seen this before? Pfsense is just a firewall, I can't see how it can be doing anything that the Playbook would be aware of. I'm wondering if it's an MTU issue? Everything should be 1500 though.
