Ultra annoying, backups work fine with CBT enabled, then you svMotion the VM and on the next backup run CBT fails and needs to be reset. In order to reset it the VM has to be power cycled a couple of times.
Is svMotion not a block based move? If the source and destination blocks are identical, why does every backup software under the sun drop svMotioned disks from CBT?
What am I missing?
What am I missing?
