Why does my RAID0 SSD array have nearly double write speeds while in safemode?
Bense
I cannot for the life of me figure out why this is occurring. I first thought that my PERC H310 (LSI 9240-8i rebadge) being in a slower PCIe 2.0 x4 host slot was my bottle neck so I then moved it to the PCIe 3.0 x8 slot. I still received the same results. Thinking that the slower processor on the H310 might be the culprit, I swapped it out for a PERC H700 (LSI 9260-8i rebadge). And even then I'm still at nearly the same speeds. I then ran the same tests on the H700 while in safe mode and my write speeds are nearly twice what they were in normal boot.
System Specs:
* ASRock X99M, i7-5820K @ 4.4 GHz
* 4x4GB DDR4-2400
* 3x240GB SSDs. Various models. All of them have over 500 MB write speeds. I have benchmarked them individually and they achieve well above 450 MB/s writes.
* slot1 - pcie 3.0 x16 - radeon r9 290
* slot3 - pcie 3.0 x8 - perc h700 raid controller
* slot4 - pcie 2.0 x4 - nvidia gtx 770
* OS: Win 8.1 x64 enterprise.
I have disabled indexing, windows defender, windows search, and everything I can think of. All of these tests were performed with no background processes occuring. I am running the latest perc firmware on this card along with the latest drivers.
verifying that SSD trim is in fact enabled:
C:\Windows\system32>fsutil behavior query disabledeletenotify
DisableDeleteNotify = 0
Benchmarks:
H310 in PCIe 3.0 x8 slot, normal boot
H700 in normal boot (note that they're nearly the same as the H310)
H700 in safe mode
background activity? In safe mode nothing is running. Just a thought.
also did you verify this with another benchmark utility? If it doesn't happen in another utility it could be a benchmark issue. ATTO does use compressible data. If the issue exists with another utility then it was reproduced with two independent tests.
