Why do they not use copper ?
micah
Reading the reviews on the new 6800 I started thinking. Why do they use Aluminum and not copper on graphic cards heat sinks ?
They seem to keep getting bigger and bigger yet they stay with Aluminum instead of switching to copper like CPU heat sinks use. I am sure it could figure out a way to support the extra weight as it is not all that much. I would say they could get away with a smaller copper one than they can with a aluminum ones. Might even being bale to stay in just the 1 bay and not take up the extra PCI slots like so many are not days.
And even that (Using a PCI slot) brings up a point in how they could help support the weight. They could build it so that both the APG and PCI was supporting it. I have seen things that used the PCI slot as support that was just plastic or something so it could not short anything out or anything. But that could help support a lot of weight between the 2 slots.
Well anyway does anyone know why they are not switching to copper ? Even some are copper coating them like MSI. I have the MSI 5900XT and it looks like it is copper but I read where it is just copper coated aluminum.
weight, its all about the weight. your questions are valid ones , but remember this is just a pre production model so who knows , what the other companys might come up with.
2 things,
#1 is that not all boards have a pci slot next to the agp slot, so you can't use it for support.
#2 aluminum is cheaper, lighter, and the differences between the two aren't very big, the design of the cooler has much more effect than the material it is made of.
Gold is a better heat conductor than copper, but we don't see pure gold heatsinks for pretty obvious reasons.
haha
when i become rich and famous, ill have me a 6800U with a gold heatsink :D bling bling
dude, you're wrong there, gold isn't a better heat condudctor then copper
in response to the topic, copper isn't a wonder heatsink
it's slightly better than copper, but alu is better when you factor in weight and cost, like others have already said.
with the pricetag on these cards, they should be gold lol
actually gold is a worse conductor then copper, but still better then aluminum.
Thermal Properties of Materials
Thermal Conductivity, W/cm-K
Aluminum 2.165
Gold 2.913
Copper 3.937
Silver 4.173
Diamond (room temperature) 6.299
Originally posted by DryFire
I think he's confused between electrical and thermal conductivity
it's approximately the same deal for electical conductivity, copper is still better than gold
sorry for the nitpicking, but i have nothing better to do
Originally posted by berky
I want daimond heatsinks!!!!!!!!!!!!!!!!!!! :D
I wonder why no one has made any thermal paste with diamond instead of silver? I did a little google'ing a while ago and was able to find diamond powder at or smaller to the size that arctic silver uses, and it was cheap too. I guess their won't much of a market for it since there is very little improvement using silver over zinc oxide (cheap white stuff), and i doubt there would be any improvement for using diamond over silver...
I'm pretty sure that Nevin of Arctic Silver has tried to use diamond in a thermal paste before. I think he determined that he didn't work very well, especially considering the high cost.
