Why do only Northbridges have...
SerialThriller said:
Why is it only Northbridge chips have a heatsink?
Memory controllers and such are on there; that's a LOT of logic, and a LOT of signalling.
So they heat up more.
Anyway, high-featurecount southbridges (notably nForce2 MCP-T) can get hot enough that a heatsink becomes useful. It's all in the amount of processing and data flow through a given chip.
Basically the Northbridge connects cpu to memory and controls pci bus, agp and level2 cache and a bunch of other stuff. Basically allows communication with the cpu through the fsb and such so you can see why it gets hot enough for a need of a HS or a HSF. Basically if your OC'ing you'll need to cool your Northbridge for sure if you want a stable OC and a higher one for that matter too.
Then again the Northbridge can't do everything by itself, so it requires a southbridge. The Southbridge controls all I/O functions, audio, usb, system bio, IDE channels and such, ie. the easy stuff which doesn't require really a need to cool via a HS or a HSF.
But that doesn't mean you can't slap one on. It's basically not necessary on a southbridge.
