I have a TF560 A2+ motherboard, and just now installed winxp home using a flash drive with a guide i found on the internet. The installation went fine, but when i got to the very end of the installation, the last 10 minutes took well over an hour, and i didnt get a chance to configure lan, user accounts etc. either, skipped right through it.
So when i boot up without the flash drive, it says "verifying dmi pool" or something of the sort, and just sits there. in order to get into windows i have to put the flash drive back in, and when the option comes up for installing windows under text or gui, i select gui and it boots into windows.
This really isn't a big deal as it is working fine so far, but i would still like to get it fixed.
I'm thinking of installing w7, but i dont have a dvd drive. could i simply download it and run the installer without using a disk/flash drive?
any help would be appreciated
edit; just restarted the computer after installing nvidia drivers, and it brought up the verifying dmi pool data. i restarted it a couple times to see if it would go away, it didnt. i then went into bios, selected optimized defaults, and set the usb as 1st priority, and was able to log in like normal. surely its not normal for the bios to forget settings?
