I am a sucker for punishment...after loosing all my data using Freenas, I have installed Nexenta Core and this was working great till:
In my eadavour to get WOL (wake on lan) working with my system, I ended up giving up because of my graphics card not supporting suspend and resume correctly.
So I have decided to go with this solution:
http://www.simerec.com/PCS-2.html
I have connected the PCS2 to my NAS and I just couldn't keep the PC to stay off, it worked ok with the remote control but when I switch the pc off it rebooted straight away.
Anyways to try and get the SIMREC to work I managed to somehow get the NAS in a reboot loop, so I have unplugged the pcs2 from my NAS and rebooted...
Now I can't access the NAS via the network, I have tried using Putty and napp-it to no avail, looking at the lcd screen that is directly connected to the NAS all seem well, when Ii boot up I get to the login prompt as per usual and can also access mc.
Anyone got any idea on how to get my NAS to be accessed again via the network?
Your help is greatly appreciated.
